Disabled my shift lock...finally.
Old Nov 13, 2015 | 09:05 AM
  #41
4SUMERZ's Avatar
4SUMERZ
Here is a PDF or removing the radio surround console that I made from previous threads and posts from forum members. Note: The Auto and Manual console is the same. Sometimes the pics disappear from threads, hence why I saved them to the PDF.
File Type: pdf
Old Nov 13, 2015 | 10:40 AM
  #42
EVRose's Avatar
EVRose
I only had to disconnect the traction control button so I could raise the console up high enough to do the job. The console does not need to be taken all the way off and no other connectors had to come off.
Old Nov 13, 2015 | 08:41 PM
  #43
tennblkc6's Avatar
tennblkc6
ditto..
Old Nov 13, 2015 | 11:24 PM
  #44
desue's Avatar
desue
Pictures are worth a thousand words, thanks to all who have taken time to post them
Old Nov 15, 2015 | 04:31 PM
  #45
Bruze's Avatar
Bruze
Originally Posted by GOLD72
Prying the trim piece loose really isn't the challenge. It's going to be all of the electrical switch connectors in back that all seem to have varying means of unlocking from the wiring harnesses. I did my 07 A6 vert a month ago and that was my great frustration.
How much time did you spend from start to finish?
Old Nov 16, 2015 | 01:37 PM
  #46
FLETCHTL's Avatar
FLETCHTL
Default Mechanical override
Originally Posted by Snagle
I drilled a small hole in the pawl and ran a wire to the inside if the center console, right by the power outlet. This allows the locking mechanism to function as designed, but gives me a mechanical override to move the pawl whenever needed.
Snagle,
I was starting to have problems with Park on my 07 and so I followed your advice for a mechanical override. It works perfect - thanks for the advice.
TF
Old Nov 17, 2015 | 01:28 PM
  #47
GOLD72's Avatar
GOLD72
I was proceeding slowly and carefully but it was certainly less than 2 hours. I am sure that I could do it in less than 60 minutes the next time. I had already done my disassembly research beforehand.
Old Nov 17, 2015 | 03:25 PM
  #48
04DarkShadowGT's Avatar
04DarkShadowGT
This is easily accomplished in an hour. I did it in less than that and I took the radio out to hook up wiring for an external amp. Only tricky part is making sure you are removing connectors properly. Some were tricky.
Old Jun 10, 2016 | 02:20 AM
  #49
Jimmy W1's Avatar
Jimmy W1
I have a question. Do you have to disconnect the battery cable when you do this job? I'd like to do this fix because mine sticks in park all the time.
Thanks.
Old Jun 10, 2016 | 07:42 AM
  #50
Jimmy W1's Avatar
Jimmy W1
One other thing, I noticed that in post # 1 and in post #18 two different guys are wiring back two different pieces. Which is the better piece to wire back?
Old Jun 10, 2016 | 04:24 PM
  #51
RICH 28's Avatar
RICH 28
No, it's the same piece. When you remove the console you will see the how the locking pawl gets in the way and how it works.
Old Jun 12, 2016 | 09:55 AM
  #52
Jimmy W1's Avatar
Jimmy W1
Is there a thread on here that shows how to remove the console? I remember seeing one but I can't find it now. Do you have to remove the shifter ****?
I gotta get this done.
Old Jun 12, 2016 | 10:20 AM
  #53
Jimmy W1's Avatar
Jimmy W1
I have also been wondering.......I always carry two fobs with me when I take mine out. Could this be a problem- the computer trying to read two fobs?
Old Jun 12, 2016 | 10:54 AM
  #54
4SUMERZ's Avatar
4SUMERZ
Thanks.
No, you do not have to disconnect the battery.
Old Jun 12, 2016 | 10:57 AM
  #55
4SUMERZ's Avatar
4SUMERZ
Look at post # 41 for radio surround console removal.
No, you do not have to remove the shifter ****. The shifter boot can be lifted out of the way towards the shifter **** to get access to the locking pawl.
Good luck.
Old Jun 12, 2016 | 12:42 PM
  #56
EVRose's Avatar
EVRose
No, that would not cause this to happen. It's strictly mechanical.
Old Jun 12, 2016 | 09:15 PM
  #57
GOLD72's Avatar
GOLD72
Good luck.
I can confirm that. I tried to remove the **** with no success. It was unnecessary.
To Disabled my shift lock...finally.
Old Jun 13, 2016 | 10:22 AM
  #58
Jimmy W1's Avatar
Jimmy W1
I just started a new thread asking this question-
Do you have to take the car out of park to get the console off?
I'm right in the middle of taking it apart and I'm down to lifting the console up but I can't do it with the shifter in park.
Help please.
Thanks.
Old Jul 5, 2016 | 01:06 PM
  #59
dtmusec's Avatar
dtmusec
It's been getting worse and worse and after being stuck for half an hour on Saturday I decided enough is enough and disabled the shift lock on Sunday. Took about an hour. Did not have to take the console all the way off. Only disconnected the active handling switch harness and the passenger seat belt light then propped the console up on the e-brake handle. The red thing is propping the shifter cover up.
Here's an updated picture.
Why did you drill the hole?
Old Jul 5, 2016 | 01:15 PM
  #60
dtmusec's Avatar
dtmusec
Would you mind if I called you on this? I am new to this website, is giving a phone number allowed?
Dale
