Disabled my shift lock...finally.
Today I drove by the dealer to make an appt for the #13146 "LOW-BEAM HEADLAMPS INOPERATIVE" recall notice, and the service rep asked me if I had had the shift cable replaced. He said "Does it get stuck in Park?", so I explained the history and my "fixes". He said I was lucky, and that one day the shifter cable would break and I would be stuck, doors wouldn't open, couldn't start car, all sorts of tales of biblical proportion doom and gloom. Said this was a prob with a lot of 06's, but sorted out and fixed for the 07's. Said many 06's got stranded, had to be towed in, etc., etc. Said the fix was about 3 hrs of labor, had to get under and "drop the bottom" to get to the shifter cable assembly (yes, he knew it was an A6, specifically talked about the A6), luckily they had one in stock bc it was a chronic issue, and as you know, 3hrs in the dealer's shop plus parts will run $400-$600 as mentioned above, he estimated about $500.
So question is (and I think I know the answer, but maybe some more knowledgeable wrenchers can enlighten/correct me), am I being taken?
The procedures described above (great photos and descriptions, btw!) appear to be straightforward, even for a knuckle-busting shadetree mechanic like me. I think I can do this, and if I have a prob, I would probably call GOLD72 (you remember I have your '72?).
Would appreciate comments about this, especially about the trustworthiness and so on of the dealers service rep, and anything else stated above.
You guys rock, thanks for making CF such a terrific resource and sounding board!
Also see here: https://www.corvetteforum.com/forums...-a4-vs-a6.html
So if the dealer installs a new cable for you, the car can still get stuck in park via the locking pawl. The dealer will probably want to sell you the whole shifter assembly for much more money to correct the locking pawl issue.
I just picked up a brand new shift cable today at my local dealer because I broke mine while putting on a new bushing. I lifted the cable too high and it snapped.
dealer BS. GM sorted nothing out after MY2006. My 07 vert suffered both park lockout solenoid problems and split cable grommet. My son's 08 coupe also had lockout solenoid problems.
Here's an updated picture.
. I think the summer heat is taking a toll on these cheap plastic parts.
btw, GOLD 72 (now called GW, for "Golden Warrior") will be back on the road soon, have replacement rubber hoses for tank lines to fuel pump that need installing, others were OEM and supply side rotted and failed. Hope to meet up someday and say hello!
