MGW shifter question. Side to side gate
Leeds.io
St. Jude Donor '14-'15-'16
SOLVED. Had to tighten bolt much more than expected.
Hey all. Just installed [mostly] the MGW shifter. Feels great and I'm excited to get it all buttoned up and go for a drive. One question I have though is regarding the side to side movement. It seems like it just freewheels between the 3-4 horizontal and the 5-6 horizontal. Not that it moves by itself but there's no force in between either. It definitely clicks in and out of the 1-2 horizontal and the same with the 7-R. [btw I can't get into R...normal while off? Yet I can just move the shifter and let it sit in the 3-4 or the 5-6 as if there's no real fixed center point.
Take a look at the video and you can see what I'm talking about. For all I know the stock one does it and I'm simply not remembering that fact. I just want to make sure everything is correct before putting all the trim back in.
Thank you!!!
best,
Gene
EDIT. Jump to post 5.
EDIT. Also noticed that it moves a lot back and forth while in a gear. I imagine it's not supposed to do that. That may be the reason for the sloppy center gate?
see here..
help!
Thank you!!!
best,
Gene
see here..
help!
it shouldn't do that, maybe it not installed right!! i didn't install mine yet but it obvious that it shouldn't do that, if i was you i would contact MGW
check this vid it installed different than what you have
Embedded Gene's vids:
Leeds.io
Thank you! I was rocking the mobile when I posted.
So what does everything think is the deal? I've seen instances of where this has happened with the MGW but not a solution. I'm certain that I screwed something up and that it's not the shifter.
Thank you!
Thank you!
Leeds.io
SOLVED. See post 1
So here's the issue. The shifter is moving a good bit before the linkage bolt turns. See video below. No matter what I do I can't get them to move in sync. Suggestions?
That rolling can only happen if the bolt that goes into the remote transmission piece isn't quite in the 1/2 round slot and tight. Go back and check that the bolt is caught in that half round. Use a really bright light. Once in place and tight, your issue will be solved.
phantasms (02-22-2017)
Leeds.io
Best,
Gene
Turbotalon1g (04-21-2021)
So what do you think of it Gene? This is yet another mod that's been tugging at my automotive psyche.
I have also been considering this mod for quite some time but haven't pulled the trigger. How small a torque wrench do you need to avoid this problem?
No torque wrench. Watch videos. Firmly hand tighten is fine, no need to crank on it. The key with that particular bolt is following procedure I posted above. Once that bolt is lined up with the half round notch, when tightened its held securely captive.
...and the shifter is well worth the price and relatively easy install.
Its anyone else having issues getting in reverse with the MGW? That's my main complaint with it.
Gene, still liking it?
