[Z06] Yella Terra rockers
Yella Terra rockers
Hey guy's, I'm installing a set of Yella Terra roller rockers on a pair of the stage 4 heads that I purchased from AHP. My question is there is 2 different flat spots on the shaft the rockers are attached to. This is where the bolt goes through, which side of that shaft points down and rests on the pedestal that the bolt tightens it to. I don't know any other way to explain it.
Also is it normal to have the back of the rocker so close to the head when its mounted? It's like 15 thousandth of space its very close but not quite touching.
And yes they will be very close to the valve cover surface area of the heads, but no worries they wont hit.
Also I didn't mean the rocker is close to the valve cover but rather it is very close to the body of the head itself.
Here is a video on assembling LS1 style rockers.
Here another install how to on a LS1 style YT Rocker, how this helps.
http://www.ls1howto.com/index.php?article=21
If I were you I would run a small spacer under the valve covers - it's the setup I am using.
I bought a set of Katech covers, if I keep them my spacer set up will be for sale. The YT supplied thicker gasket is a marginal solution, you can and will end up with the rockers brushing the covers (not good).
PM if interested.
PM if interested.
This is the kit that Tony Mamo sold me when I purchased my YT Rockers from him last year.
https://www.briantooleyracing.com/ye...er-yt5132.html
Brandon619 (03-25-2017)
Double check your "wipe" on top of the valve stem. After I checked mine with one shim I realized I needed a second shim to get it just right, and I had to order them from YT in Australia. Took 2 weeks!
Mine came with the shims.
All I can say is with the rubber spacer, the valve cover position is very sensitive, and you will only know if they are touching if you use a mechanic's stethoscope.
Just providing the information, do with it what you will..
I had a set and the rockers were rubbing on the pedestal and the rocker cover. .625 lift on an LS7..........LME discovered the rubbing on the pedestals when LMR sent them the heads to be done. They did the required machine work on them and no more rub. So after I did that one of the rollers on a rocker went bad. Had a not too easy time getting YT to cover it. Later decided that I should just switch to CHE rockers and problem is solved.
That looks good but your rockers are 1.7 where as the same rockers for an LS7 is 1.8. Just a wee bit bigger.
Brandon619 (03-26-2017)
