Just seeing if I learned how to post pix.
St. Jude Donor '14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Just trying out something here.... posting a couple of pix of my 2 Vettes just to see if I can. So, you can just ignore for now
If you want to test some more, go to "forums" at the top gray bar, then "help and feedback", then "testing" and post to your heart's content.
65GGvert - thank you for the tip. I did not know about that. I'll try it out, and not clutter the 'regular' threads w/my tests. Appreciate it.
KC John: Well, that was part of the testing, which, I guess, I failed, because the second pic, the one of the 64, didn't make. However, I've changed my Avatar, which now shows the 64. Also, I continued the test, in another post, and was able to successfully post a couple of shots of the 64. Thanks for the comment about the 58.
https://www.corvetteforum.com/forums...elp-guide.html
What's under your User ID is an avatar.
What you created was a profile pic. It doesn't go anywhere.
