Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
will C6 wheels fit on my C5?
Old 09-07-2005, 11:47 PM
racemy99corvette
4th Gear
racemy99corvette's Avatar
Default will C6 wheels fit on my C5?
do the stock OEM wheels from a C6 fit on C5's?
Old 09-09-2005, 07:40 PM
Cruisin Chrome
Cruisin Chrome's Avatar
No they will not.
I do have C6 wheels though in the correct fitment for the C5.
Frank
Cruisnchrome.com
Old 09-13-2005, 10:37 AM
AMGPilot
AMGPilot's Avatar
Yes the C6 wheels fit on a C5 but of course you have to change the tires as well
Old 09-13-2005, 11:33 AM
racemy99corvette
4th Gear
and the offset is the same?
Old 09-13-2005, 12:43 PM
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
the offset of a C6 rear wheel is 79mm and a C5 wheel is in the 60's so, they will not fit properly
Old 09-14-2005, 12:42 AM
Mr. Lucky
Mr. Lucky's Avatar
St. Jude Donor '06
YES, no problem. However, the positive offset on the C6 rear wheels is greater, since the C6 body is narrower. A 1/4" hub-centric spacer is needed for proper track in the rear. Forum member vetterdstr used to run these on his C5 vert. Here is a picture of his car with C6 OEM wheels:
Old 09-20-2005, 11:49 AM
SpinMonster
SpinMonster's Avatar
The calculation of offse tis relate to the width on a wheel. Just because you see 2 different numbers doesn't mean the wheel wont fit. The rear offset on the 2004 Z06 wheel is not the same as a stock wheel due to the two wheels being a different width.
A hubcentric spacer works fine even in drag applications. I know because I did it. My cousin's 2002 trans am is also running stock C5 wheels (from me) for 2 years now with spacers and he drives it like he stole it.
Don't take info from people with no experience.
Old 09-30-2005, 12:37 PM
cenzo
cenzo's Avatar
A 1/2 inch spacer would be better since it will just about cancel the 14mm difference in offset (79mm-65mm) 'tween C6 and C5 wheels, putting the center of the wheel back where it belongs in the wheel well. The wheel will stick out nearly a 1/4 inch further than stock C5 because its a 1/2 inch wider - but who cares?
I hope this helps.
Old 10-18-2005, 03:42 PM
Joe Fetchel
1st Gear
Joe Fetchel's Avatar
Default C6 Wheels & Tires for sale
I own a C6, and I'm buying new wheels and tires, I need to sell my C6 wheels and tires first, The wife said so Stock chrome wheels with stock C6 tires only $2,000.00 Call me for details.
Joe Fethel
Orange county California
(714)437-7700 WK
(949)495-1753 HM
(949)842-3792 Cell
jfetchel@aol.com
Old 10-14-2014, 08:48 PM
50th Anniversary Z06
3rd Gear
50th Anniversary Z06's Avatar
http://baltimore.craigslist.org/pts/4691006384.html
Can ANYONE tell me if these will fit on my 2003 Zo6?
Old 10-17-2014, 07:57 PM
lectroglide
lectroglide's Avatar
Speaking of wheels My 92 has some very nice chrome C6 5 spoke wheels, Im looking to swap for some ZR-1 type wheels, anyone interested gimme a shout
Old 10-20-2014, 09:25 AM
mrr23
mrr23's Avatar
St. Jude Donor '15
Yes with a slight rub on the rear inside. Use a 1/4" spacer to clear that. They will stick out about an inch all around.
https://www.corvetteforum.com/forums...with-pics.html
The 325/25-20 is 26.3 tall whereas my 325-30-19 is 26.7 tall. This will give you a little more fender clearance.
To will C6 wheels fit on my C5?
Quick Reply: will C6 wheels fit on my C5?
