Lug Nut Torque setting
I have a C-7 and the manual says the lug nuts should be torqued at 100 ft. pounds. I have several friends with C-6s and C-7s and some of them are torqueing their lug nuts to 110-115 ft. pounds. Any advantage or dis-advantage to using 110-115.
Received 19,305 Likes
'20-'21-'22-'23-'24
My advice - follow the torque specs in the manual - they are there for a reason. I've heard that over torqueing the lugs may cause the rotors to warp.
Although I don't have any positive proof, over-torqueing could also potentially strip wheel studs or crack wheels.
