Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
C6z wheels on a c5
Old 08-22-2015, 06:11 AM
jonrobinson84
jonrobinson84's Avatar
Default C6z wheels on a c5
I have an 00 model c5 and would love to put some stock c6z wheels on. I hear the wheels may cause a rubbing issue and then others say there is no rubbing. Any opinions?
Will any year c6 wheels work
Are the c6z wheels the same as rest of the c6 wheels.
mrr23 (11-04-2015)
Old 08-22-2015, 10:55 PM
RC000E
RC000E's Avatar
C6Z's have different offsets. One member here that I know of has successfully put on C6Z wheels with a 325 rear tire and it sits dead flush. He has a Z06, and had to remove his rear brake ducts for them to clear. The fronts poke every so slightly, but if you're slightly lower or have a wee of camber dialed in, they look perfect.
They can work, but if you're a traditional kind of fella, I'd look elsewhere. They have C6Z reproduction wheels in C5 offsets so they sink inside of the fenders like the stock wheels do...
mrr23 (11-04-2015)
Old 08-25-2015, 10:36 PM
jonrobinson84
I do kind of like the tire being even with the fender, makes it look pretty slick in my opinion. Not sure about adjusting camber and I am sitting stock so they may not look as good.
mrr23 (11-04-2015)
Old 08-27-2015, 04:39 PM
raz0rbladez909
raz0rbladez909's Avatar
These are OEM GS wheels, but they're the same sizes/offsets as c6z wheels. The wheels obviously won't fit right with the OEM tire sizes, but if you don't mind a little stretch they can be made to work. These are my daily wheels so it didn't bother me to have a little stretch.
mrr23 (11-04-2015)
Old 08-27-2015, 04:42 PM
raz0rbladez909
Here's a couple threads to helo you
https://www.corvetteforum.com/forums...my-c5-z06.html
https://www.corvetteforum.com/forums...-z06-pics.html
mrr23 (11-04-2015)
Old 08-29-2015, 02:29 PM
mrr23
mrr23's Avatar
St. Jude Donor '15
and another one with all your answers
https://www.corvetteforum.com/forums...only-pics.html
Old 10-01-2015, 09:04 PM
chain_5001
chain_5001's Avatar
Here's mine with oem c6z wheels. I'm using 3/16" spacers. Sticks out a bit but it looks ok....I think.
mrr23 (11-04-2015)
Old 10-02-2015, 01:58 AM
jonrobinson84
Looks really good. Spacers front and rear?
mrr23 (11-04-2015)
Old 10-02-2015, 02:04 AM
chain_5001
chain_5001's Avatar
3/16" spacers on the rear only. No spacers up front. 325/30/19 tires in the rear and 275/35/18 in front, Michelin Super Sports. I'm at stock ride height. Still have the brake ducts in there also. It is a tight fit, but everything works just fine.
mrr23 (11-04-2015)
To C6z wheels on a c5
Quick Reply: C6z wheels on a c5
