Not sure if this has been addressed, but why can't the CAGS (1 to 4) in an M7 be user configurable like the performance exhaust (on/off)?
Most drivers hate the 1 to 4 forced shift
CAGS has to be left engaged with an error if disconnected or deactivated. Otherwise the car will get hit with a lower EPA mileage number. It's why if you disconnect it, you'll get a CEL. Obviously the work-around is the plug-in resistor, but GM will never (and can't ever) authorize that or any other work-around.
Does installing a CAGS bypass violate or otherwise affect the warranty?
Only if it causes a problem and can be proven to. If you take your car in because the radio is misbehaving, the dealer will be hard pressed to prove that the bypass you installed is causing that. If the transmission is throwing some sort of code for some reason, the dealer may be able to prove the bypass is doing that.
I've never heard of the bypass causing any problems whatsoever, assuming it's not installed into the reverse lock-out solenoid plug versus the CAGS one. Doing the former will, of course, prevent you from engaging reverse, and is a common first-timer's mistake. But easily corrected.
If you're in a performance mode like track and CAGS is disrupting your experience...I can tell you, that you have a lot more problems than the elimination of CAGS will fix
Touring mode - normal driving. The CAGS is annoying, but want to be sure that installing a CAGS bypass will not violate the warranty. If it does, than I will simply put up with it until the warranty period is over.
I look at CAGS as a gift from GM. It's easily defeated with a resistor, and GM knows that. But they and Tremec put it on the car which increases the car's EPA-tested mileage. And in doing so, the Corvette either misses completely or has a significantly reduced gas guzzler tax applied to it.
CAGS has existed on GM manuals since the very early 90s. It's not going anywhere. The best you can do is either deal with it by driving past its RPM range, or just buy the resistor.
[tongue-in-cheek] It is user configurable. Want to turn it off? Drive more aggressively [/tongue-in-cheek]
LOL - I can always try that! Seriously though, it's worse than annoying - perhaps dangerous - when driving in congested traffic and the CAGS won't allow a timely shift, and you are losing speed while the car behind gets too close.
To the best of my understanding, in the limited explanation I was given by a couple of the Corvette engineers was, that the EPA mandated mpg test involves speeding up and slowing down, simulating rush hour on the 405 essentially. There is a screen in front the operator/tester of the car, and you must throttle to keep up with what the screen demands. It also commands you to shift, due to rpm. The issue is, they stated that the shift command parameters were developed a LONG time ago, when transmissions weren't 6spds and 7spds. So, GM engineers came up with the idea to shift to 4th instead of 2nd, since the usable torque of the motor could handle it, and thereby pass the test in terms of MPG requirements.
Basically, it's a system designed to do well on an outdated testing system mandated by the govt. The engineers don't want it there, any more than you or I do.
BTW...I see you're from Chalfont...interesting...lol. I worked Turtle Creek PD years ago...years ago...
1800 miles on a 2015 Z06 and CAGS hasn't kicked in once. Is it on the Z06 or maybe they missed mine.
Ha! They probably didn't miss yours - it won't do a thing, depending on when you shift. Mine rarely activates. It's more likely when traffic is stop and slow. I can't recall the RPM when you'll see the message and feel the bypass when shifting, but I think it's around 2000 or 2200 RPM. As others have suggested, just carry 1st gear a little higher than normal and you'll most likely never have to mess with it. Have a great day!
Reason: Better word choice
CAGS can be a nuisance. Especially if you are uphill behind some slow poke and a short shift to second gets you buy him rather than getting the rpm up in first to allow second.
I had an aftermarket tuner put in the jumper and fixed the problem on my 07 Z06
Easy fix w/ the resistor. Costs about $1 and takes about 2 min if you have your car on a lift or stands. Hopefully GM will leave it the way it is, in order to meet the silly EPA rules & avoid (or reduce) gas-guzzler tax.
It'd be interesting to find out CAGS real world impact on fuel economy, as it's probably offset by drivers simply revving it higher than they might normally do, just to avoid the skip shift.
I've had three CAGS vehicles, all equipped with a CAGS eliminator, one of the easiest mods you will ever do. Zero negative effects. The dealer could care less. Game over.
