Glitch after MRC Update
I got the MRC update ($350). Ever since then i have noticed the issues below:
- When i select the steering to stay in tour mode (via touch screen selection) - it does not stay in tour mode when i select track mode via the drive selector.
- My exhaust has become significantly quieter since the update (even though its set to track mode via touch screen). Fixed this by resetting to factory settings via touch screen.
- I also noticed that the suspension is very stiff in tour mode, it feels like i am in track mode the entire time (i am not sure if this is normal for the update).
I noticed in the bulletin that it says 2014/2015 vehicles will also require MRC module software and utility file updates along with calibration files. My vehicle is a 2015 z06, could these issues have been caused by the failure to update the files mentioned above? or could it be due to an improperly performed update?
UPDATE: After extensive testing this morning I've confirmed that the suspension is stuck in either sport/track mode in every mode. My best guess is that it is stuck in track mode ( it feels similar to the non-updated track mode).
