Ask Tadge Archived: Corvette's Chief Engineer Tadge Juechter answers questions from the CorvetteForum community.
What maintenance requires dropping the engine / transaxle?
Old Mar 6, 2020 | 06:00 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Default What maintenance requires dropping the engine / transaxle?
We've now seen at least two reports that changing out the accessory belt(s) requires dropping the engine. Previously, GM personnel stated that "normal" maintenance would not require the engine to be dropped. Also, that the C8 meets or exceed all GM standards for service times.
Does the engine need to be dropped to change the belt(s), alternator, water pump, or other front of the engine components? Which ones?
Thanks!
Old Mar 7, 2020 | 09:24 PM
ChiTownVetteTech's Avatar
ChiTownVetteTech
I’ve looked through the whole manual and found that belts,alternator, starter, intake and exhaust manifolds, balancer all serviced in vehicle. Anything the oil tank has to come off for is an engine out service. For example heads, and coolant crossover. The water pump oddly isn’t listed separately. Not sure why as I haven’t checked how part is serviced.
there are other items that require rear crossmember removal only such as mounts and oil pan.
trans replacement only requires engine support and not complete powertrain removal.
there is a large access panel in the trunk for air box and top of trans access
Heater and evaporator core requires both doors and cross car beam removal.
As a tech the only thing I worry about is top
of engine and work in trunk access as I’m leaning over taller rear quarters than lower front fenders and vehicles with the high wing spoiler are going to be a little challenging.
As I always say for a pro it’s all just nuts and bolts. I don’t find it anymore difficult than any of our other vehicles. It’s still not as tight as a diesel pickup.
I am trying to find some good fender covers for the C8’s.
Old Mar 13, 2020 | 12:09 PM
RapidC84B's Avatar
RapidC84B
@ChiTownVetteTech You have to take the freaking doors off to work on the AC or heater core! WTF! I know you can mark the bolt heads, but I wouldn't trust many tech's to take the time to make sure the door is aligned perfectly. Also where are you going to lay a door assembly with door panel to where the "beak" doesn't get damaged or the interior door panel doesn't get scuffed up?
Old Mar 13, 2020 | 10:25 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just curious, what's the reasoning there?
Old Mar 13, 2020 | 11:17 PM
ChiTownVetteTech
I wouldn’t stress this so much. It’s only for repairs requiring hvac case removal. In 25 years of working on vettes I can count on one hand how many times I’ve removed an hvac case. 2 of them were for rodent problems.
I completely understand how you all feel about some of the techs (I use that term loosely) that work on these cars. I have seen plenty of bad through the years.
I can’t reinforce enough to get to know your dealer tech. If I had to ever pull doors be it on a Vette or a Cruze I would take care of it as it was my own. They wouldn’t be laying on the floor and would get lined up as good as the day they were installed.
Old Mar 13, 2020 | 11:25 PM
RapidC84B's Avatar
RapidC84B
Can you get the cluster screen and console screens out without pulling the dash? They had some infant mortality on C7s.
What about the HVAC blend door? That failed on a few C7s.
My local dealer tech has been solid, but I’m a perfectionist and he’s trying to make a living getting laid book time. I usually tip him.
Old Mar 14, 2020 | 12:44 AM
ChiTownVetteTech
the cluster and center display come out after you pull apart some trim. Hvac doors would most likely require hvac case removal. It’s not the dash that need the doors off. It’s the a cross car I/p tie bar. It has 2 long bolts on each side that go in sideways through the door jamb.
Thats funny “getting laid book time”. Sometimes it feels like it.
Old Mar 15, 2020 | 11:31 AM
RapidC84B's Avatar
RapidC84B
Lol... “paid”.
To What maintenance requires dropping the engine / transaxle?
