From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Yes is the answer. Here is a post from a member on the same topic from the General Discussion Section.
"Or adjust the volume level of the blinkers. It is adjustable, yet even at lowest setting it is still audible! But, better than at full volume!!
Using the Driver Information Center Controls (DIC) on steering wheel, scroll to "Comfort and Convenience" then select "Chime Volume". Set at lowest setting and see if that helps.
Page 118 of owners manual -
Chime Volume. This setting determines the chime volume level. Touch the controls on the infotainment system to adjust the volume."
