Sponsored by: Innova
rear 5.25 speaker replacement
Old Mar 2, 2005 | 08:37 PM
uforic C5's Avatar
uforic C5
Default rear 5.25 speaker replacement
would like to chance out my existing bose 5.25 rear side speakers,, question is can i use a after market like sony 4 ohms speakers ,, or will the bose system not push this,,,,,
Old Mar 3, 2005 | 12:22 AM
fdxpilot's Avatar
fdxpilot
I have Infinity I5.25s in mine. They work well.
Old Mar 3, 2005 | 12:30 AM
snoopdan's Avatar
snoopdan
oh god, not this again
You need to read Bogus's sticky FAQ document. It answers this question.
The short answer is yes, you can use 4 ohm speakers, but it will not function properly with the bose amplifiers as they accept 1 ohm speaker impediences.
What happens when you put your newly purchased aftermarket speaker on the bose amps???? Nothing....it will work O.K. but no where near effeciently as it was originally designed to work as. It wont be near as loud as it could be....thats all.
snoopdan
Old Mar 3, 2005 | 11:46 AM
Jody19SebringGS's Avatar
Jody19SebringGS
You can use 4 ohm aftermarket speakers to replace the rear side speakers in a C5. These do not have Bose amplifiers, and are powered directly off the head unit. The two 7" woofers in the door are the only speakers with the Bose amps. (The FAQ sticky is for C4's, which do have the Bose amps in the rear).
I thought the rear speaker size for coupes is 6.5". Or do you have a vert or FRC? I believe those are 5.25".
Old Mar 3, 2005 | 12:20 PM
leolufse's Avatar
leolufse
This is completely correct.
Old Mar 12, 2005 | 01:49 PM
ace67's Avatar
ace67
It seems to me that its you that should read the FAQ based on your answer
snoopdan
Old Mar 13, 2005 | 09:55 AM
Bigcat39's Avatar
Bigcat39
Old Mar 13, 2005 | 12:34 PM
snoopdan's Avatar
snoopdan
my bad, I thought he was a c4'er. I dont even look at avatars anymore...im not perfect, and by no means a guru. I never intend on giving anyone the wrong info
snoopdan
To rear 5.25 speaker replacement
