Sponsored by: Innova
C5 3 way components
Old Mar 4, 2005 | 08:10 PM
BlueOval Convert's Avatar
BlueOval Convert
Default C5 3 way components
How many people have installed a 3 way component system(6,4,tweet) in their C5 corvette? Where did you mount everything? Can it all mount behind the speaker grills in the doors? Does anybody have any pictures of their installs? Thanks
Old Mar 5, 2005 | 01:18 AM
bogus's Avatar
bogus
Yes. It will work... just requires some creative cutting to make the baffle.
Nelson V. has done this, and you wouldn't know until you heard it. The install is totally stealth.
I would recommend CDT 3-ways. They come very highly recommended. If you can find Canton Pullman RS3s on eBay, get them.
Old Mar 5, 2005 | 09:16 AM
EatRice's Avatar
EatRice
I had a set of MB Quart 8",4", and tweeter in mine behind the grill. The only problem I had was blocking the tweeter with my leg. Other than that it was sweet. THe C5 has a ton of room in the door.
Old Mar 5, 2005 | 10:04 AM
ltnate's Avatar
ltnate
I put the CDT 643 in my car. I got VrumVrum http://forums.corvetteforum.com/member.php?u=42258
a forum member to make me a mounting plate to fit behind the speaker grill. I place the 6 and 4 behind the grill and put the tweeter in the door. The hardest part is getting the nerves to cut the doors for the tweeters.
Old Mar 6, 2005 | 01:07 AM
Nelson V.'s Avatar
Nelson V.
Tweeter: 1" Dynaudio D28
Midrange: 3" Dynaudio MD140
Mid-Bass: 6.5" Scan Speak 18W/8535-00
Old Mar 6, 2005 | 03:32 AM
C55797's Avatar
C55797
1st Gear
that dome midrange is sweet. how did you build your crosover?
Old Mar 6, 2005 | 06:24 PM
Nelson V.'s Avatar
Nelson V.
Crossover points between these three drivers are handled with a "roll-your-own" network of passive components (capacitors, inductors and a couple L-pads). Tweeter and Mid are one amp channel; mid-bass on its own amp channel. Crossover between mid-bass and subs is handled with an active crossover in my in-dash PEQ.
EDIT- Here's a sketch I've been working on; this is one half of the drivers/amplification:
To C5 3 way components
