Sponsored by: Innova
C5 Stock HU pre-amp outputs. Will this work?
Old Mar 7, 2005 | 04:34 PM
comecorrect's Avatar
comecorrect
Default C5 Stock HU pre-amp outputs. Will this work?
Will this work? I have a stock C5 HU and a bazooka powered subwoofer. My plan is to splice a set of RCA cables into the HU pre-amp output wiring harness and plug it into the sub. I will use connector C4, wire (11) LR Brown, (12) RR Dark Blue, and (14) Bare wire for both common. Will the signal work? Thanks!
MIKE
Old Mar 7, 2005 | 07:17 PM
Grzldvt's Avatar
Grzldvt
Some feel there is not a full signal coming out of the rears. So I would tap the fronts just to be safe. In my tests with different speakers, it certainly sounded like I was getting full range, and could even get them to overwhelm the fronts, but others have had different experiences.
Have you seen this Tech Tip?
Bose Wiring Tips
Old Mar 7, 2005 | 08:37 PM
snoopdan's Avatar
snoopdan
It really doesnt matter if it is full range or not for what he is doing. Its not like Bose is going to have the foresight to bandpass their lower fequency drivers so they dont recieve fequencies below 120hz. Thats an easy way to go for sure! There are some inline plugin RCA line level converters that www.p-a-c.com makes. Its in the OEM interface section of the site.
Also, depending on what model of Bazooka tube you have, it may already have line level inputs built in, which well negate the use of wiring in actual RCA conectors to the tube amp. That way, if you dont want to pull your deck nor pull the wires to the amplifier completely out, you could just wire the signal inputs to the tube from the speakers themselves. Either way will work.
snoopdan
Old Mar 8, 2005 | 02:12 AM
vetterlatethannever's Avatar
vetterlatethannever
snoopdan is right on the money!
Old Mar 8, 2005 | 09:25 PM
comecorrect
THANKS GUYS! I hooked up the bazooka last night. The install was easy. It sounds much better. I'm going to replace the front 3.5" and rear 6.5" speakers this weekend. Thanks again.
MIKE
Old Mar 8, 2005 | 09:48 PM
markcz's Avatar
markcz
MIKE
Did you use your original plan to tap into the HU preamp outputs to get a bass signal for the Bazooka? I'm just curious because I recently tried to tap into the front and rear twiddlers to supply a bass signal to a Bazooka and the low end signal wasn't present in any of the signals coming from the Bose amps that went to the stock twiddlers.
TIA
Old Mar 8, 2005 | 11:27 PM
comecorrect
TIA
Yes I used the HU pre-amp outputs.
Old Jul 29, 2025 | 08:45 PM
SideOfTheRoad's Avatar
SideOfTheRoad
Sorry to revive a 20 year old thread, but had to thank the original poster, ComeCorrect. I had the same question, followed your advice, and it worked beautifully. You saved me a lot of headaches using this method to tap in RCA outputs to my subwoofer. Thanks again!
Old Sep 15, 2025 | 08:13 AM
Mibs1's Avatar
Mibs1
5th Gear
Is it correct in my connection in the picture? It is hard to see in your photo, can I use a black wire for ground instead of a wire in a transparent braid? Is it correct in my connection in the picture? It is hard to see in your photo, can I use a black wire for ground instead of a wire in a transparent braid?
Old Sep 15, 2025 | 08:53 AM
Mibs1's Avatar
Mibs1
5th Gear
MIKE
Correct?
Correct?
Old Sep 15, 2025 | 11:20 AM
SideOfTheRoad
Use the bare braided wire for the shielded ground for the signal.
Old Sep 15, 2025 | 12:27 PM
Mibs1's Avatar
Mibs1
5th Gear
Is it correct diagramm?
Old Sep 15, 2025 | 12:28 PM
Mibs1's Avatar
Mibs1
5th Gear
my diagramm is correct?
Old Sep 15, 2025 | 04:21 PM
SideOfTheRoad
Correct. Do not tap into the black sheathed wire.
Old Nov 3, 2025 | 04:28 PM
Mibs1's Avatar
Mibs1
5th Gear
i need in this connect hi low adapter? or does the output of the RCA go directly to the input of the RCA amplifier?
To C5 Stock HU pre-amp outputs. Will this work?
