Sponsored by: Innova
New C5 Vette System Install
Old Mar 9, 2005 | 04:44 PM
PhoenixCIS's Avatar
PhoenixCIS
Default New C5 Vette System Install
So I have ordered the following:
Alpine CDA-9833
CDT CL61a
JL Audio 10W6V2
Phoenix Gold Xenon 100.2
Phoenix Gold Xenon 400.1
Rockford Fosgate 4 Guage Multi-Amp Wiring Kit
So, what else do I need (outside of wiring harness and h/u mounting bracket)? Any suggestions on where to mount the amps? Any general knowledge anyone would like to share before I start the install? I will be building my own speaker box (which is better, MDF or Plywood?). I will also be building my own speaker mounts. I have searched this forum for as much info as I can, but I figured I would ask now that I have everything here (or on its way)
Thanks in advance!
-Brian
Old Mar 9, 2005 | 04:58 PM
scott_fx's Avatar
scott_fx
i'd say mdf but if you want to save some weight go with birch plywood.
I'd also pick up the panel removal tool for $5 so that you dont break anything.
multimeter is a must since you'll have to tap into another mire harness to get an acc. lead.
Old Mar 9, 2005 | 10:19 PM
Vate's Avatar
Vate
Drop an email to crxguyQQQ@mindspring.com and I'll send you speaker box plans for the rear storage area if you are interested. (take out the Q's).
Old Mar 10, 2005 | 08:21 AM
Ebein's Avatar
Ebein
Alpine CDA-9833
CDT CL61a
JL Audio 10W6V2
Thanks in advance!
-Brian
Im not familiar with those amp specs but if your running around 500w+
your going to need a cap or your lights are going to be flickering.
As for amp mounting if they will fit side by side between the rear
speakers is where ive seen most multi-amp set ups. If they wont
( like mine ) you can mount one between the rear speakers and
one against the rear center cargo wall over the larger storage compartment.
It seems everyone uses MDF, its a very strong material. Plywood
tends to split if you are put screws in the edges, where MDF usually
wont.
Old Mar 10, 2005 | 09:41 AM
knewblewkorvette's Avatar
knewblewkorvette
I would have to disagree just on this point. The C5 has a good stock altenator compared to most cars. As long as you used 4-guage (or larger) wire you should be fine.
Old Mar 11, 2005 | 12:57 AM
dan_ltdbrands's Avatar
dan_ltdbrands
I have two amps, Audiobahn-65x4 and a JL 500x1 with two sets of tweeters, a compenent set, and a 12 JLW6V2. My lights do dimm a little when the sub hits but you don't really notice unless you are looking for that. If you are going to do anything I would suggest upgrading the stock ground from the battery to at least a two gauge. And if you want to go all out, you could even upgrade the alternator too! That, however is a little costly. At the least though, definately upgrade the grounds.
Old Mar 11, 2005 | 08:29 AM
EatRice's Avatar
EatRice
You should upgrade the grounds and the positive from the alternator to the battery before anything else. Also having a solid fresh battery will help...something like an Optima red top.
As mentioned about MDF and plywood. Birch plywood is lighter and stronger but costs twice as much and is harder to shape. MDF does an excellent job but is heavy. BOTH will split without the proper fastening technique. That would predrill and then screw or use a staple gun. With either material make sure to use wood glue on all the seams.
Old Mar 11, 2005 | 01:47 PM
leolufse's Avatar
leolufse
Check out the "big 3" upgrade in the tech tips section of this forum.
Old Mar 14, 2005 | 01:14 AM
PhoenixCIS's Avatar
PhoenixCIS
i picked up an optima red top today.
ill be in tennessee till thursday, so assuming everything gets heret his week, i should be good to go this weekend.
thanks for the help! and keep it coming.
To New C5 Vette System Install
