Sponsored by: Innova
Where to install front laser diffusers?
Old Mar 20, 2005 | 10:06 AM
Vespa-Vette's Avatar
Vespa-Vette
Default Where to install front laser diffusers?
I'm putting this on a C6 but anyone can aswer this question.
Does the diffuser need to be flush mounted with the leading edge of the car or can it sit back a little, maybe up to an inch behind the leading edge?
On the C6 without a front plate, I figure the best place to hit the car with radar is to aim for the front lights? So, I plan to mount the two diffusers wide in the front grill opening near each headlight.
Any suggestions?
Thanks!
Old Mar 20, 2005 | 11:37 AM
knewblewkorvette's Avatar
knewblewkorvette
sounds like you are heading down the right path. The C5 will be extremely hard to get with a laser, even with a shot at the head lights.
No flat surfaces to reflect back a signal, it even helps a tad with radar.
I think you'll be fine with your idea.
