Sponsored by: Innova
Another HU selection criteria question
Old Mar 28, 2005 | 03:09 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Default Another HU selection criteria question
I've planned on providing a L & R preamp signal to the amp that'll power my subs. Since I'm going with two 8" subs and have enough power from a 2 channel amp, I wanted to provide a stereo signal to the subs and not mono.
Questions:
1. Can you tell the difference from 8" subs - stereo vs mono? Obviously I was thinking I'd be able to tell . . .
2. If I pass a preamp signal from my 4 channel amp to my two channel amp, is it passing the front or rear preamp signal (or neither) and/or will the HU fade control effect the signal being sent from the 4 channel amp?
Old Mar 28, 2005 | 03:12 PM
scott_fx's Avatar
scott_fx
what amps are you using?
and in a properly tuned system you shouldn't be able to tell the difference between mono and stereo on the subs.
Old Mar 28, 2005 | 04:54 PM
74-Roadster
St. Jude Donor '06
Audiobahn A1504DP (digital - 4 channel) 150w x 4 @ 4 ohm
Audiobahn A3201T (A/B - 2 channel) 300w x 2 @ 4 ohm
To Another HU selection criteria question
