Sponsored by: Innova
Z06 speaker upgrade question...
Old Mar 29, 2005 | 03:32 PM
Icewasp's Avatar
Icewasp
Default Z06 speaker upgrade question...
Hello,
I have a 2003 Corvette Z06. I am thinking about replacing the 4 stock Bose speakers (3.5 inch fronts, 5.25 rears) with some similarly sized/better quality speakers and adding an amp to give better boost/sound to these new speakers.
Is this 'simple' upgrade as easy as swapping out the existing speakers and plugging in an external amp to power them?
I've heard that the factory C5 Corvette Bose system can be kind of squirly when it comes to 'plug and play' components.
Any suggestions/help would be greatly appreciated.
Thanks,
Mark
Old Mar 29, 2005 | 05:21 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
you just need to replace the speakers, no external amp is needed. you can get adapters from circuit city so that you do not have to cut the factory plug off of the speaker harness.
it IS plug and play.
Old Mar 29, 2005 | 06:38 PM
Icewasp's Avatar
Icewasp
Thanks for the info...
Now if I wanted to add an amp to help boost the sound of the 4 speakers, what would be the simplest way to hook that up? Would it be worth installing?
Old Mar 31, 2005 | 10:52 AM
Fastgenious's Avatar
Fastgenious
Will replacing the rear speakers add a lot of bass? Or would an infinity basslink be better? Thanks.
Old Mar 31, 2005 | 02:41 PM
RedRider98's Avatar
RedRider98
Simply replacing the speakers will not yield much better sound quality. I tried it. I ended up replacing the HU, speakers, and adding an amp and a sub. I totally axed the Bose system. You will probably find this is the way to go....
To Z06 speaker upgrade question...
