Sponsored by: Innova
no sound from '91 bose
Old Apr 27, 2005 | 09:02 PM
fudd_elmer's Avatar
fudd_elmer
6th Gear
Default no sound from '91 bose
Hi,
The head unit looks like it is functioning but I am getting almost no sound out of all speakers. If I turn the volume all the way up you can hear it play but at a very low level.
I first thought the amps got fried but I got a portable cd player and and connected it to one of the speakers - it worked!
Looking at a diagram on www.corvetteradios.com, there is a receiver box between the head unit and speakers. What does the receiver box do and where is it? There is also a speaker relay that I tried to check but had a hard time getting to it under the instrument panel - got to take the driver's seat out this weekend.
Anything more to check?
John D'Angelo
dangelo@ieee.org
Old Apr 27, 2005 | 10:13 PM
-=Jeff=-'s Avatar
-=Jeff=-
Did you go through the Amp with the portable player? from the way you are describing it, i sounds like tha capacitors on the amps are bad..
Old Apr 27, 2005 | 10:18 PM
fudd_elmer's Avatar
fudd_elmer
6th Gear
Yes, I went through the amp. The first thing I check was if the speaker had voltage - it did. I will try another speaker as well.
Old Apr 27, 2005 | 11:10 PM
bogus's Avatar
bogus
the receiver module is what feeds information to the amps. I find it odd that all 4 channels die at the same time.
To no sound from '91 bose
