Sponsored by: Innova
Amp fuse - where to install?
Old May 9, 2005 | 01:20 AM
vectorz's Avatar
vectorz
Default Amp fuse - where to install?
I understand that the rule of thumb is "18 inches from the battery". Can it be closer? I'd like to have the fuse next to the battery, under the hood... rather than in the cabin under the passenger feet.
Old May 9, 2005 | 01:23 AM
EatRice's Avatar
EatRice
Close to the battery is good. 18" is a rule made by an organzation called IASCA. That fuse you does not protect your amp it protects your car. Incase your power wire gets shorted the fuse will blow and prevent your car from catching fire. So as close to the battery as possible is good.
Old May 9, 2005 | 02:00 PM
OrthoAggie's Avatar
OrthoAggie
i use that...it is fused AT the battery, and i didnt have to mount a separate fuse holder in my already cramped engine bay
To Amp fuse - where to install?
