Sponsored by: Innova
ppi.....too many options
Old May 20, 2005 | 06:43 PM
onaqwst's Avatar
onaqwst
Default ppi.....too many options
i have a ppi6600 and am running the jl 6",4",tweet component set... well since the 6600 has crossovers and other options on it, should i not hook up the component crossover and just run them straight from the amp....... not really sure..... i'm trying to utilize the amp to the best of it's ability and running just one set of outputs doesn't really make sense to me...... any suggestions
b
Old May 20, 2005 | 09:06 PM
EatRice's Avatar
EatRice
I could not find info on the 6600 so can not answer you exactly but to run your three way set using the internal xovers of the amp you will need to have six channels of amplification. You will also need to have 6 channels for the xovers. Each pair of channels will need to have it's own xover that is adjustable to fit the speaker it is going to power. If your amp can do that then you are all good. If not then it would be best to use the xover that comes with the speakers.
