Sponsored by: Innova
which wires are +/-?
Old May 20, 2005 | 08:52 PM
molson's Avatar
molson
Default which wires are +/-?
I am installing rear speakers....How do I tell which wires coming from the car are pos/neg?
Any help appreciated.....
Old May 20, 2005 | 09:01 PM
EatRice's Avatar
EatRice
Here is the easiet way to tell. Use a battery...9v is usually easy to use. Cut the plug on the back of the speaker while leaving around 2" of wire. Connect one wire to the positive terminal and one to the negative. The speaker will "pop" if it moves outward the speaker is in phase. If it is in phase check which wire went to the positive terminal and that is your positive wire. If the speaker moved inward then it is out of phase. Reverse the two wires on the battery and that will tell you the positive.
Old May 21, 2005 | 04:04 AM
markcz's Avatar
markcz
For the rear speakers:
Brown & Dark Blue are (+)
Yellow & Light Blue are (-)
Old May 21, 2005 | 06:23 AM
molson's Avatar
molson
Thats what I need!!!..Much thanks.
Mark
Old May 22, 2005 | 02:33 AM
ALLT4's Avatar
ALLT4
Word of caution here. Don't ever assume it's correct. You should always check like EatRice said. You never know know if someone else or even the factory screwed up somewhere on the wiring.
Old May 22, 2005 | 06:09 AM
molson's Avatar
molson
Thanks for replys.I got them in and they sound great!!
To which wires are +/-?
