Sponsored by: Innova
Replaced my DDs with IDMAXs
Old May 23, 2005 | 09:34 PM
OrthoAggie's Avatar
OrthoAggie
Default Replaced my DDs with IDMAXs
I replaced my DD3510Cs with a pair of IDMAX 10s. They are much taller and have a slightly larger cutout so the only thing i could do without rebuilding my box was to build a pair of spacers. I machined some spacers out of 1 1/4" thick acrylic blocks. I have not decided if i am going to polish them or leave them hazy yet...
Old May 24, 2005 | 12:46 AM
OrthoAggie's Avatar
OrthoAggie
Old May 24, 2005 | 06:33 AM
JimNY's Avatar
JimNY
Man that's some setup.
Crank it up and I'll hear you here in NY
Old May 24, 2005 | 12:38 PM
Kale's Avatar
Kale
How much room in those boxes?
Old May 24, 2005 | 01:59 PM
leolufse's Avatar
leolufse
I assume the blurry picture is when you had the system crankin'
Old May 25, 2005 | 02:42 AM
OrthoAggie's Avatar
OrthoAggie
around 3 cu ft after all the displacements of the subs and ports
Old May 25, 2005 | 02:43 AM
OrthoAggie's Avatar
OrthoAggie
i was trying to get a picture where you can see everything with less flash as the box is black but with a flash it makes it look a lot lighter than it really is, it came out alright with really the box the only thing in focus
Old May 25, 2005 | 03:12 AM
Kale's Avatar
Kale
it takes up space in your compartments?
Old May 25, 2005 | 10:45 AM
OrthoAggie's Avatar
OrthoAggie
yes, it goes down in the passenger side all the way and just to the ABS controller on the driver side
Old May 25, 2005 | 12:57 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Hmmm, nobody's asked, but how do you like them in comparison to the DD's?
Personally, I'm very impressed with my little ID 8's!!
Old May 25, 2005 | 09:09 PM
OrthoAggie's Avatar
OrthoAggie
these are much more SQ oriented then the DDs. They have a Fs that is about 12 hz lower and can produce the low notes much cleaner and louder. They DDs are very nice woofers but i really needed a slightly bigger box then i have room for, but they can handle more power then the IDmaxs. I am somewhat pushing it with 1000 watts to each one which is the RMS so i am breaking them in slowly and not trying to go overboard yet. overall i am very happy with the switch as my system is more SQ oriented with my 3 way front stage actively xoved by my Audiocontrol DQX which also has a 30 band eq which is still currently flat as i have not had the time or a real mic to RTA it and tune it properly.
To Replaced my DDs with IDMAXs
