Sponsored by: Innova
Painting boxes?
Old May 26, 2005 | 11:10 PM
wicked 98z's Avatar
wicked 98z
Default Painting boxes?
http://www.2k1vert.com/c5/photo_gall.../photo_65.html
Im doing a box just like this one but the only thing im changing is where he installed black carpet im wanting to paint it TR to match the car. Is there any way to get the MDF board to shine like the fiberglass will? Would I have to layer the board with glass and then bondo it? or can I just add bondo to cover the board?
TIA
Albert
Old May 26, 2005 | 11:35 PM
GKK's Avatar
GKK
Spray about 4-5 coats of primer and wet sand using 400 grit wet with a rubber sanding block. Just use water from a thick sponge to keep the surface wet not drenched. The primer fills in the grains of the wood and makes the surface very smooth.
After it's painted the surface will look like metal.
Old May 27, 2005 | 08:34 AM
EatRice's Avatar
EatRice
GKK is right on. I am about to paint a bunch of MDF and when finished it will all look like a standard car finish. He did leave out that you should use a high fill 2k primer though. That will give you a good build up. Also the MDF will soak up the first coat or two...don't worry about it.
Old May 27, 2005 | 05:46 PM
wicked 98z's Avatar
wicked 98z
thanks guys
Old May 27, 2005 | 10:26 PM
OzzyC4's Avatar
OzzyC4
You can easily seal mdf with a base coat of shellac. The top coat with primer, coler, etc.
To Painting boxes?
