Sponsored by: Innova
HOT ! CD Player?
Old Jun 23, 2005 | 09:11 PM
CAJUN C4's Avatar
CAJUN C4
Default HOT ! CD Player?
Anyone exprrience a hot CD player?
Friend of mine had a 1990 that the CD Player got so hot it wouldn't play after a while maybe an hour & a half of playing........Anyone have this problem?
Swealtering in South Louisianna
Old Jun 24, 2005 | 12:49 AM
EatRice's Avatar
EatRice
Yes I have seen it several times. Clarion players have been known to get too hot to touch.
Old Jun 24, 2005 | 08:43 PM
rightofway's Avatar
rightofway
i've had this happen on my computer, and alot of the time when i remove cd's from a couple of our stereos they have been too hot to hold.
feels like summer don't it
Old Jun 24, 2005 | 10:08 PM
GSteg's Avatar
GSteg
Cruising
Is the CD player an aftermarket deck? If so, that could be the reason why they run hot. Decks nowadays are built to have more output than stock decks. Heat has to go somewhere. Often time, the heatsink on the internal amp itself is small.
Old Jun 25, 2005 | 11:33 AM
knewblewkorvette's Avatar
knewblewkorvette
yes..bad thing is....heat kills electronics
Luckily, your's shuts down before the HU fries. Two of the radios I have have no speaker outputs, another does and I don't use them, and the 4th which I do use all the speaker outputs get HOT but has never shut down. I look at putting a fan in there but no room.
If your's is getting overheat protection, you might want to look at somehow getting air to your HU
To HOT ! CD Player?
