Sponsored by: Innova
Radio Question
Old Jun 27, 2005 | 05:44 PM
pwrful c4's Avatar
pwrful c4
Default Radio Question
I have a 94 with a non Bose system.will a bose c-d radio work wih out Bose speakers?
Old Jun 27, 2005 | 06:05 PM
bmwdiver's Avatar
bmwdiver
yes but it will require some significant additions, an additional amp will definitely be needed, it is possible to tap into preamp outs on the back of the radio and use those as your lo input to your amp, but not really sure why you would want to, the bose ( also known as BLOWS ) system is not very good. unless you want that factory look if this is the case let me know and i'll post the factory radio pin out and let you know which wires to tap into
Old Jul 3, 2005 | 02:07 AM
Reddy94's Avatar
Reddy94
I also have a 94 non bose. I want to gut the entire thing and upgrade. Is there a thread with the necessary details? How difficult is it..Can it be done in an afternoon etc...and special wiring needed? I have the faceplate adapter and new HU. Little apprehensive about tearing it up and finding out I don't have everything necessary. I'm in Italy and have to order all parts etc...from the states.
Thanks Guys!
Old Jul 3, 2005 | 02:02 PM
bogus's Avatar
bogus
YES.
The head unit is a dummy... the key to bose isn't the CD head unit, it's the receiver module (under the dash on some years, in the rear compartment in others).
after studying the Helm manual, I can state, with near 100% certainty, that a "Bose" CD head unit will work fine with a non-bose system.
It does not require the amps... it does not require a different receiver.
Why GM didn't put the CD in on Delco systems strikes me as pure marketing and perhaps, a Bose restriction that CD be a bose only thing. I donno.
Go for it. It should work just fine. Plug and play.
Old Jul 4, 2005 | 01:07 AM
Reddy94's Avatar
Reddy94
Thanks Bogus...Do you know if there an old thread that has the procedures for replacing the H/U with an aftermarket for a 94 non bose...From reading the posts I see that I only have to disconnect and bypass the receiver in the back... I have searched and cannot find one with detailed instructions...
To Radio Question
