Sponsored by: Innova
Cor-Har Wiring Schematic
Old Jun 28, 2005 | 04:42 PM
silverdog's Avatar
silverdog
Default Cor-Har Wiring Schematic
I am trying to connect an XM Commander in my 2001 C5 using Cor-Har and GM Aux-10. Do I splice the power wires for the XM Commander into the 3 wire side of the Cor-Har. If so, on the three wire side of the Cor-Har, there are a black (assume ground), a red and a green wire. The XM Commander has a black (ground), a yellow (marked Battery) which is a hot wire? , and a red wire that is marked (Accessory). How do these hook up? Does the XM yellow power wire go to the Cor-Har red or green wire. There used to be a connection schematic here on the Forum but I can no longer find it. Thanks for your help.
Silverdog
Old Jun 28, 2005 | 05:55 PM
ChefBoy's Avatar
ChefBoy
The power wires are in the footwell, "hidden" up near the left top of the fuse panel. The Cor-Har plugs into the two connectors at the lower right corner of that area. These cables aren't for power.
Check out the C5 and General Audio FAQ at the top of this section for some good advice.
Good luck
CB
