details, .............how hard? What is behind the H/AC controls?
Was actually very simple..The only thing I had to modify was I removed the stand-offs for the radio than reshimed for the HVAC unit depth and a few new holes in the plastic mounting tabs.
The AVIC unit had to be shimmed out some, I moved it as close to the top as possible so it would clear the shifter, the face plate fit up under the cross bar on the dash plate and filled in the space under the HVAC unit.
no mods needed to any wires or plugs the HVAC opening is a bit deeper than the radio opening.
Radioactive is an audio store in the Atlanta area. The faceplate was a generic filler plate. everything else came with the unit. I did have to have a kit (soundgate bose interface ) to hook into the Bose speakers.
It took most of the day to work out the install I mounted the GPS unit under the glove box.
