Sponsored by: Innova
C4 Amp Location
Old Jul 11, 2005 | 01:56 PM
pologreen91's Avatar
pologreen91
Default C4 Amp Location
I've finally gotten tired of the noise coming from the right rear speaker so I'm going to do something about it. Is the amp directly behind the speaker or at least someplace close? Also I'd like to verify it is the amp before I change it out so can I just swap the right and left rear speaker/amp combo quickly to check it or will it require solder joints etc.?
Old Jul 11, 2005 | 03:28 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
It's in the actual speaker enclosure. Check out the C4 FAQ at the top of the sticky list.
Old Jul 11, 2005 | 03:54 PM
vetterlatethannever's Avatar
vetterlatethannever
and the "brain" for it (at least in my 93 C4) was in the back storage compartment under the plastic tray.
Old Jul 11, 2005 | 08:36 PM
techguy's Avatar
techguy
Actually -- the Tuner is located in the passenger side dash .. kinda where the AirBag is ..
If its Bose - all speakers are amplified - and this is just the Tuner for the radio ..
Hope that helps ..
Techguy
soundzplus@aol.com
To C4 Amp Location
