Sponsored by: Innova
Cutting the C3 bezel for DIN
Old Jul 16, 2005 | 09:14 AM
foundvettelifeisgood's Avatar
Default Cutting the C3 bezel for DIN
What's the best tool/technique?
Old Jul 16, 2005 | 09:20 AM
Metal Wulf's Avatar
Metal Wulf
buy a repro that's already been cut
Old Jul 16, 2005 | 09:36 AM
I believe they are $200 plus shipping.
Old Jul 16, 2005 | 10:58 AM
EatRice's Avatar
EatRice
I use an air saw with a fine tooth blade or a dremel tool. A hand saw with a fine blade will work also. I recommend that you mark the piece before cutting, then cut to about 1/16th from the mark. Then use a fine file to bring your cut all the way to the mark. You will end up with a much cleaner finish on your cuts.
Old Jul 16, 2005 | 08:28 PM
Motor City Vette's Avatar
Motor City Vette
I used a carbon fiber cutting blade (actaully, quite a few) in my Dremel...worked fine.
Old Jul 17, 2005 | 05:41 AM
diviniti's Avatar
diviniti
St. Jude Donor '05
If you have a dremel, you can also stuff a "Roto Zip" bit in it.
I usually get a few packs of (Metal) Rotozip bits. Work great for cutting plastic/metal/fiberglass etc..
Old Jul 17, 2005 | 01:27 PM
Metal Wulf's Avatar
Metal Wulf
use the trim plate as a template for the cut, then a dremel will be your best bet.
To Cutting the C3 bezel for DIN
