I'd love to but I've bought cheap wire before and that's exactly what I got, cheap wire that sounded like crap. Goes with video as well. Try hooking up a dvd player with regular RCAs and then hooking it up with component cables. Much better quality. Since I am doing this install, I'll splurge for the extra wire costs.
Composite to component on video is way different than comparing the same thing to audio.
A wire is a wire is a wire, it's all copper... just get the right gauge.
but it's your cash, if you want to overspend get the stinger stuff.
Speaker Wire Size:
It is not necessary to run large gauge speaker wire to have good quality sound. 16g lamp cord is perfectly fine in almost every situation. Even the stock wiring in the car is usually perfectly fine (the exception may be only when there are OEM amplifiers in line with the speakers). If someone tells you that you have to replace the stock speaker wires with large gauge wire to have good sound quality, they probably don't know what they're talking about.
Yea, just ordered the Stinger Dream interconnects - two 20' of those, 20 ft. of 0 AWG power wire, 8 ft. of 4 AWG amp wire, 6 ft. of 0 AWG ground wire, 20 ft. of 18 gauge remote wire, a dual foot ground terminal, and a partridge in a pear tree.
if you can't see the difference on an o-scope or on a RTA then it's pretty safe to say that wire is wire. lamp cord is 16ga for the most part and it will handle 120 ac at 60 hz for 15 amps. translate that to wattage audio and that is 2300+ watts at 60hz rms. go buy some lamp cord at home depot 100ft for $14 and you will be happy!
Even though I bought the Monster Cable XP speaker wire 16ga? which is still pretty cheap.
I'm also using the second cheapest Monster RCA's. If you have a HU, preamp or line driver up front that's putting out 5-10 volts of signal, noise won't be an issue sending signal to the amps with the cheaper cables.
