Sponsored by: Innova
Switched power lead C5
Old Aug 11, 2005 | 05:44 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Default Switched power lead C5
Is there an easy way to tap into a switched power wire for my amp and XM modulator? The last thing I want to do is hack into the wrong place!
Old Aug 11, 2005 | 06:21 PM
scott_fx's Avatar
scott_fx
(check the c5 faq )
Old Aug 11, 2005 | 07:45 PM
markcz's Avatar
markcz
Check out post #4 of this thread to see how to make the amp come on with the radio and stay on with RAP if you're keeping the stock HU.
Old Aug 12, 2005 | 09:01 AM
Chicago's Avatar
Chicago
St. Jude Donor '15
Is there anything to tap into near the head unit? I'm installing a PAC audio interface, and there is a wire on it for a ignition switch.
Old Aug 12, 2005 | 09:21 AM
c5golfguy's Avatar
c5golfguy
Cruise-In IV Veteran
St. Jude Donor '10
In the passenger foot well, you will need to remove the carpet and the cover to the PCM located under your feet. There will be a plug with 3 wires on it. One has switched, one has constant, one has ground. Look in your owners manual, it will also describe it. Tap into these wires. It will be a plug with 3 wires hanging off of it going to no where. Looks weird, but tahts what you want to use to tap into switched.
Old Aug 13, 2005 | 01:57 AM
markcz's Avatar
markcz
You can use the switched wire in the above post and it will work fine, that's how I originally had my Neo Jukebox power connected. The only problem is that when you turn off your car the radio will stay on with RAP until you open a door, but everything you have powered with the ignition wire will turn off. If you'd like for the aftermarket stuff to stay on you'll need to tap into the RAP wire. It doesn't seem like much, but it does get annoying after a while, especially when you know that you can have it all working properly.
To Switched power lead C5
