Sponsored by: Innova
Question about head unit fit in a C5
Old Aug 28, 2005 | 12:41 PM
GTrain's Avatar
GTrain
St. Jude Donor '14
Default Question about head unit fit in a C5
I looked in the audio thread, and I know that I will need an adaptor to work witht he Bose, but different sites conflict on what will and won't fit in a C5.
I was planning on one of the Pioneer DEH units that are usually an exact fit for the large face GM radio. But some sites say it won't fit a C5
Do these fit ? Anything else I need to do it myself ?
Recomendations ?
Old Aug 29, 2005 | 04:19 PM
GettReal's Avatar
GettReal
Recomendations ?
I will try to help you a bit by telling you that you can pretty much fit anything into the C5. a single din unit will fit but you will require a faceplate to close off the extra space. there is a forum member here (vrum vrum I think) that sells nice clean ones.
a 1 1/2 din should fit since its the same size as the OEM but there arent many to be found
a double din will fit with some slight modification to the trim and there are a couple threads posted recently including mine where I added a double din HU.
if you look up on an automated site what fits the C5, you will get a typical response that says not much, as its not a direct replacement size but the reality is you can pretty much get anything to fit.
IM not familiar with that specific unit but I cant imagone why it wouldnt fit... good luck and maybe others can help out as well
Old Aug 29, 2005 | 08:48 PM
GTrain's Avatar
GTrain
St. Jude Donor '14
I prefer a 1 1/2 din to just plug and play. Half the sites out there conflict on what will and won't work...
To Question about head unit fit in a C5
