Sponsored by: Innova
Best 4 ohm amp for sub
Old Aug 31, 2005 | 02:08 AM
minytrker's Avatar
minytrker
Default Best 4 ohm amp for sub
I have a Pioneer Premier TS-SW124D which is a 4ohm sub that can handle 300rms/1200 peak watts. I am having a hard time finding a good amp at a good price. Anyone have this sub, if so what amp are you using?
Old Aug 31, 2005 | 02:15 AM
bogus's Avatar
bogus
check the JL Audio e series.
Old Aug 31, 2005 | 02:33 AM
scott_fx's Avatar
scott_fx
check out the phoenix gold ti series as well. i have one and it was great.. i cant bring myself to sell it even though i have recently replaced it
Old Aug 31, 2005 | 03:02 AM
minytrker's Avatar
minytrker
The amp needs to be atleast 400x1 @4ohms rms. I am also trying to spend less than $300 if that is possible.
Old Aug 31, 2005 | 03:11 AM
scott_fx's Avatar
scott_fx
have you checked out the jbl line?
Old Aug 31, 2005 | 07:36 AM
knewblewkorvette's Avatar
knewblewkorvette
You can get a JBL BP600.1 (used) off e-bay for less than $150. It is a sub amp only, class D, and is 600 watts rms at 2 ohms but 300 watts rms into 4 ohms, perfect for a 300 watt rms sub. Why you say 400 watts needed is If you have some other reason, get a 1200.1, it will give you 600 watts rms into 4 ohms, but cost you about $260.
Old Aug 31, 2005 | 11:13 AM
minytrker's Avatar
minytrker
I have heard of jbl but always thought it was lower end. I have never seen it at any of the stereo shops I go to. The reason I wanted atleast 400 rms is I like to have a little more power and be able to turn the amp down vs having just enough. Plus with the sub being in a small sealed box you can run some extra power without hurting anything.
Old Aug 31, 2005 | 11:45 AM
knewblewkorvette
True, JBL is not on the level of the JL Audio amps, but the price difference is huge. I use them in my C5
To Best 4 ohm amp for sub
