Sponsored by: Innova
Kenwood DDX 7025 installed
Old Sep 10, 2005 | 10:12 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
Old Sep 11, 2005 | 07:23 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Good looking system...
Is that a double-din unit???
Old Sep 11, 2005 | 08:40 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Nice and clean - looks really good!
Old Sep 11, 2005 | 09:08 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
tempting, very tempting, I've also got and old Kenwood amp in storage.
Old Sep 11, 2005 | 11:07 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Awesome!
Old Sep 12, 2005 | 09:41 AM
Ray8's Avatar
Ray8
Yes, it is a double-din unit. However I mounted it without the frame that comes with it. This mounting-frame didn't fit.
Old Sep 12, 2005 | 10:43 AM
Impala Balko's Avatar
Impala Balko
that is a sweet head unit i wanted that one but that system is worth some long dough. does the face flip when loading cd's or DVD's and how is clearance with the shifter. Is yours a M6 or an Auto. could you do up a pic with the face fliped so we can see the clearance.
Old Sep 12, 2005 | 06:48 PM
jimmyd's Avatar
jimmyd
Good job !
Old Sep 13, 2005 | 03:20 AM
Ray8's Avatar
Ray8
The face flips when loading CD's or DVDs and the clearance is tight - needs some minor adjustment in the corners and the back of the original cover.
I uploaded an additional picture where you can see how it opens .
Mine is an Auto. You can't load the disc when in park - if you have an MN6 this should be no problem.
Old Sep 13, 2005 | 09:05 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Nice
Old Sep 13, 2005 | 11:45 AM
dnut24's Avatar
dnut24
see thats exactly what i was concenered about. the auto stick being in way. but i figured you'd have to have it in drive to load disks.
i was looking at adding a single din folsing screen with a single din head unti below and was worried about the clearence. thanks for the pics.
Old Sep 13, 2005 | 01:58 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
I've seriously considered installing that unit into my '91 but the last time I was in the dash, it didn't look like there was enough room.
I've already cut the back support brace out but the bottom of the opening looks too shallow. Did you have to do any custom work back there? Do you have any pictures of the installation process?
Old Sep 13, 2005 | 03:19 PM
  #33
Achilleus07's Avatar
Achilleus07
Two thumbs straight up man that is more than awesome
Old Sep 13, 2005 | 03:39 PM
  #34
sremenap's Avatar
sremenap
Firstly - that looks fantastic.
Couple questions for you. Did you replace the speakers (i am assuming that you did) - if so, what did you use for the whole system. Did you put a 4 channel amp inline, and did you attempt to increase the speaker size in the back.
I would also like to know if you purchased a harness to ease the installation process, and how tight the space was in the dash for installation of that bad boy.
As you can see - i am about to do this myself :-)
Thanks in advance for the info.
Old Sep 13, 2005 | 03:48 PM
  #35
Ray8's Avatar
Ray8
I had to cut back the plastic behind the radio. On the picture you can see, what a friend of mine on his '96 GS had to remove. I cut the whole plastic below the air condition holder - not only the marked area in this picture - so there was enough room for all the cinch cables.
Old Sep 13, 2005 | 04:01 PM
  #36
Ray8's Avatar
Ray8
I know that most of you changed the speakers, because they don't sound very good when using the original GM radio - but with this one - the Bose system get's a wake up!! So I decided to keep the active speakers and the Bose unit in the rear which controls them. However this system doesn't deliver hundreds / thousands of watt of music - if you want this you should change the speakers.
There is a standard adapter cable available for GM Radio. You have to connect this to the cinch cables which go into the Kenwood system. I also put some Video in / out cinch cables in the rear compartment box - just in case I need to have a TFT screen attached or the PS2 ..
However I need a kind of adapter because the system still powers the speakers when trying to shut them of. Due to the speakers being active ones, I have a bang on the speakers when I turn of the radio if I don't switch to "standby" before powering down the radio... I heard that there must be a kind of adapter available for this common problem...
@dnut24:
Nice wheels! Could you please email / post a picture of your C6 wheels on the C4????
Old Sep 13, 2005 | 04:42 PM
  #37
ShawnZR-1's Avatar
ShawnZR-1
Excellent picture of the dash!
Well, if that's the case, you only had to cut the plastic piece out, then I'm in good shape!
Time to consider spending some $$!
Oh, did you use any sort of installation kit to mount the radio?
To Kenwood DDX 7025 installed
Old Sep 13, 2005 | 04:49 PM
  #38
n1kki6's Avatar
n1kki6
Nice i am going to be getting a kenwood double-din next MN vette season.
Old Sep 13, 2005 | 04:55 PM
  #39
pwrful c4's Avatar
pwrful c4
Awesome,any problems with the install?
Old Sep 13, 2005 | 05:38 PM
  #40
boulderlt4's Avatar
boulderlt4
That is sweet!!
