Sponsored by: Innova
Equalizer/Amp Install
Old Oct 12, 2005 | 07:32 AM
CorvetteSteve's Avatar
CorvetteSteve
Default Equalizer/Amp Install
Is it possible to use an Equalizer that has a built-in amp, in the same system you have a 600 watt subwoofer amp in?? I guess this would be an Active Eq as opposed to Passive. The Sub Amp is being used for a rear sub only.
