Sponsored by: Innova
Need Wiring Help Quick
Old Oct 15, 2005 | 12:05 PM
bayarea9's Avatar
bayarea9
Default Need Wiring Help Quick
I have a 95 that orginally came with the Bose Gold system. I am currently trying to put in a new Alpine H.U and use the existing wiring. I looked at the C4 stickey and it says that the Ignition Wire should be Yellow. Problem is i dont have a yellow wire in the old wiring. What color is the Ignition Wire supposed to be???
Also what wire was the ground wire for the Bose system?
Since I have your ear, just to double check, the power wire is orange and the power antenna is pink right?
Thanks so much in advance
Old Oct 15, 2005 | 02:53 PM
1COOLPC's Avatar
1COOLPC
I don't have the exact answer you're looking for but do you have a multi-meter or test light? If so just test the leads until you find one that gets power with the key on. That's what I do when I don't know for sure.
Old Oct 15, 2005 | 04:42 PM
bayarea9's Avatar
bayarea9
I have been trying that with a volt meter to no avail. :-( Is there somewhere close to the HU area i can splice a wire into?
To Need Wiring Help Quick
