Sponsored by: Innova
Car Audio Question.
Old Oct 28, 2005 | 08:29 PM
bauhaus's Avatar
bauhaus
Cruising
Default Car Audio Question.
Hi everyone. I wanted to change my speakers in a 1984 C4 with Bose Speakers. I was very dissapointed, I went to CircuitCity, Bestbuy, and they said that they don't touch vettes. I also called up GoodGuys but they all closed here in California . Where do you guys get your speakers changed?
I was thinking about just changing the rear with stock Bose because they don't work anymore.
Also, My antenna goes up but gets stuck halfway, and the motor on it is still running, I have to pull it all the way up but it still doesn't work. The same thing happens when it is supposed to go down, it gets stuck half way. How do i Fix that?
Old Oct 28, 2005 | 08:53 PM
bogus's Avatar
bogus
oh, dear... you have no idea about bose, do you?
Each speaker is amplified, you don't just "replace the speaker". this is an all out committment - either get it all fixed, or, replace it all.
Check out the Audio/Electronics section (where this should be, really) and read the C4 Audio FAQ.
From the pull down menu, Forums ==> General Corvette ==> Audio/Electronics.
Old Oct 28, 2005 | 09:08 PM
Leftoverture's Avatar
Leftoverture
There are direct replacement speakers with amps and all available at several places on line. Try Mid America or similar. . .
Old Oct 28, 2005 | 09:13 PM
Scott-89's Avatar
Scott-89
Unless you want to remain totally original, replace it all. I am going to replace all of mine this winter. I have an 89 and some of the speakers take awhile to kick on and then they don't sound the best.
Also here is the link for the Audio Section Audio
Old Nov 3, 2005 | 07:26 PM
bauhaus's Avatar
bauhaus
Cruising
im planning to replace all the speakers. Can someone please recommend a place to have it done?
Old Nov 3, 2005 | 09:29 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
you can seriosuly do it yourself we will guide you through it... where are you located someone maybe close by to you who is willing to help... I peronally am in the chicagoland area and would help
To Car Audio Question.
