Sponsored by: Innova
C4 door speaker box removel?
Old Nov 2, 2005 | 09:39 PM
tigmaned's Avatar
tigmaned
Default C4 door speaker box removel?
my pass side speaker amp is on the way out. i have the door panel off to change some much needed inner and outer window seals. so while i have it off i want to pull the speaker box to see whats up with the amp. but not really sure how to go about the removel?
Old Nov 2, 2005 | 09:59 PM
corvette1989bham's Avatar
corvette1989bham
Do a forum search for info , but quick version...Door panel off, pull lock rod and door handle rod out of their plastic retainers, pull the metal door plate off (will have to wiggle) then pull four screws of amp housing, hounsing will be glued in ..will take a little prying. FYI the wiring harness may get tangled up when you put it back in be careful that the window doesnt catch the wiring harness.
