Sponsored by: Innova
Bose "auto tone" button question
Old Nov 8, 2005 | 08:50 PM
Schwiiiing's Avatar
Schwiiiing
Default Bose "auto tone" button question
Is the auto tone conrol acivated by the memory buttons? Some times it's on when I get in, & sometimes not ('04). Want it on all the time...
Old Nov 9, 2005 | 03:50 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is programmed into the station that you have preset into the radio.
Old Nov 12, 2005 | 10:31 AM
markcz's Avatar
markcz
The tone mode that you select is remembered by the preset stations of the radio. Put each stations tone where you want it, then re-save that station into the radios presets.
The radio presets are then remembered by the memory buttons. Once you have all of your presets properly set, then re-program your memory button by holding the button down. All of your stations and their proper tone setting should then be available every time you unlock the doors with your fob.
To Bose "auto tone" button question
