Sponsored by: Innova
need some help
Old Nov 27, 2005 | 06:38 PM
idontknow's Avatar
idontknow
Default need some help
i just got a killer deal on a clarion touch screen dvd player. i am going to put a sub in back and all that is pretty easy to do. what i need help with is i am just going to put an aftermarket ampto run the front door speakers and rear speakers. how hard is it to tap into the existing wiring for these speakers. how much wattage can they take. i have 3 amps to choose from ranging from 45 to 220 rms watts.
i know the subs have an amp on them but does the twiddlers? are the wires ran seperate or does the wires go through the amp for the subs but never get amped?
i am going to replace them with components next year unless i find a way to buy them in the next month.
thanks for you help
Old Nov 27, 2005 | 08:12 PM
techguy's Avatar
techguy
ok - Ill try to help ..
First ..
What yr is your car . ?
Old Nov 27, 2005 | 08:20 PM
Prism911's Avatar
Prism911
The wires that run from the stock Bose unit run through a sound processor before heading off to the speakers. After the sound processing only the subs are amped.
Since you are not going to want your amped signals to pass through the sound processor or door sub amps, your would need to run new wires from the amps far enough to splice into the original wires somewhere after the sound processing and amping occurs. You might as well run new wire all the way.
But then again, I would not use aftermarket amplifiers to drive the stock speakers.
If you only want to add a new head unit and sub at this time, buy an adapter that allows you to plug your new headunit into the current wiring and that also adds the ability to use a aftermarket amp to drive a sub. Then when you are ready to install new fronts and rears ditch the adapter, install the new amps and speakers, and run new wire.
Old Nov 27, 2005 | 08:53 PM
idontknow's Avatar
idontknow
that is probably what i am going to do.
were is the signal processor and amp, i am guessing the processor and amps are in the dash some were. if so that is easy to tap in, if the amps are in the doors then that is a little more difficult and would be easier to run all new wires like you said.
anybody know were the processor and amp are located
oh, this is going in a 2000 coupe
Old Nov 27, 2005 | 09:12 PM
techguy's Avatar
techguy
The sound proccesor is located just above the gas pedal..
But - if you are planning on replacing the speakers anyway ..
Just run new wires into the doors .. Its pretty easy to do .. tons of room in the door boot -
The adaptor thats worls well is from SoundGate.. about $90- will save you a TON of time ..
To need some help
