Sponsored by: Innova
IPOD Conversion Kits
Old Dec 13, 2005 | 04:24 PM
Buddy Boy's Avatar
Buddy Boy
Cruising
Default IPOD Conversion Kits
I have a 96 vette and wanted to inquire whether anyone has knowledge of an after market kit for direct wiring my IPOD into my Delco Bose system.
Old Dec 13, 2005 | 04:31 PM
xlr8nflorida's Avatar
xlr8nflorida
I wish there was a way, not an easy way from what i can tell.
It would be awesome though, I'd like to do the same with my IPOD.
The fm transmitter is not real good
Old Dec 13, 2005 | 05:21 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
I tried all the FM transmitters, none worked real good. I finally
got a Kenwood with Sirius and an aux port, works like a charm.
Old Dec 13, 2005 | 05:48 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I have the FM setup but I use the cassette adapter it sounds better than the radio.
Old Dec 13, 2005 | 07:30 PM
artvette's Avatar
artvette
There is one that will work provided your radio has a cd changer interface. I forget the name of the company but if you Google around you'll find it.
Old Dec 13, 2005 | 08:13 PM
red-y's Avatar
red-y
I do not think so because your radio was designed soooo long ago. If you have a remote disc player there is a conversion plug available. If you have an aux. amp you can go direct. I have heard that the fm adapters have a hum or noise that is not good. NEW Radio?
Old Dec 13, 2005 | 08:58 PM
mikenfl's Avatar
mikenfl
This was my solution: http://salestores1.com/aufmfmmoanda.html
It's an FM modulator, but not a transmitter (those suck). The cable from the antenna plugs into it, and another cable runs from it to the antenna jack on the radio. When it's turned on it removes the antenna signal so there's no interference. It does have to be hard wired in to a keyed source. It comes with a tiny toggle switch that I installed beside the cigarette lighter. It has RCA plugs so you'll need an RCA to miniplug adapter cable. I ran it up through the bottom of the cupholder. When you're not using the mp3, unplug the cable, push it back down in the console and close the ashtray door; nothing visible. I liked it so much I put 1 in our Suburban. Circuit City has them.
Old Dec 13, 2005 | 09:10 PM
artvette's Avatar
artvette
http://www.discountave.net/pxpe95gmcveh.html
I believe this harness Peripheral PXHGM2 will connect an Ipod2car adapter to your 96. Most interfaces are compatible with 97 and up. This will allow an older model to use the interface.
http://www.cardomain.com/item/PERPXHGM2
http://www.cardomain.com/sku/PERPXDP
http://www.cardomain.com/sku/PERPXDX
Old Dec 13, 2005 | 09:29 PM
Torch Red Tim's Avatar
Torch Red Tim
St. Jude Donor '09
I rigged up an MP3 player through my stock Bose Gold radio, 94. FM modulator is the only way I could come up with. The first FM modulator I used sounded like CRAP. It was the kind that plugs into the antenna. I went to a shop that does this kind of work and they sold me a “stronger” FM modulator, same basic thing they just said theirs was better stronger. I switched them out, huge improvement. The part number on the good FM modulator is ATC MAKX01 $34.99. No CDs to keep up with, lots of music, I like it. The sound is not perfect but its good enough and I did not have to gut the dash and put in a new system.
Old Dec 14, 2005 | 09:56 AM
EvanD's Avatar
EvanD
CF Community Team
The poeple at Cuircit City said that the cassett adapter was much better sounding that the fm transmitter but I was worried about how the casset adapter goes in and drops and what the attached cord would do to the opening door on the radio, have you had any problems with the cord?
Old Dec 14, 2005 | 11:17 AM
hardlight's Avatar
hardlight
No problems so far, only concern is just the wire not getting tangled up anywhere. The sound is just awsome.
Old Dec 14, 2005 | 12:28 PM
xlr8nflorida
Depends on where the cord is located. I have seen some tapes where you can change where the cord exits the tape.
To IPOD Conversion Kits
