I am hooking up a Pioneer nav D1 unit in my 2006 C6. When I went to hook it up at the computer behind the front passenger wheel well, I noticed the 2006 has 2 wiring harnesses, rather than the 3, I understand the 2005 has. In the 2005, the VSS wire was located in the very bottom harness of the three, now with the 2006 just having two harnesses and several green/white stripe wires, I need some help.
Can anyone look in a service manual for a 2006 and see where this is located. I have been told it is still a dark green wire with the white tracer. CKT 817 which is pin 57 at the C1 connector. Could someone verify this and let me know which of the 2 harnesses is C1 and where the exact pin location is.
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
thanks so much
The VSS wire is dark green/white located at the cluster or ECM, blue plug, pin 21. The ECM (Engine Control Module) is in the front passenger fender. Have to remove the wheel and the access panel behind the wheel to get to it.
Also found in the radio harness on some models.
Hope this helps... if you need anything else, contact me via my site in my signature.
