Installing 2 x 12" subs in 1980 rear compartment - is it possible?
Is it possible 2 install 2 x 12 inch sub woofers in2 the rear compartment
wall - the part that is just beneath where the handle is for the curtain/cover - if so any1 have any pics of the completed job?
Or will I have to install a box just in front of the wall?
My main concern is not being able 2 properly store my t-tops if I have 2 go the box route - also ruins the interior / originality
Any useful replies much appreciated
10" in the corners with fiberglass molded box....amps on bottom and still room to have tops....
u can make a box to fit in the rear compartments and mount the amps to the back wall....easier that way.... 1 jl 10w7 or 1 jl10w6v2 will be enough for bass....
b
i made the amp setup out of solid acrylic.... then painted...... i might redo the setup though....... not sure yet....
b
b
Yeah, you could definitely fit 2 12s if you wanted to. But if I were you I'd just use one, a good one. With such a small cab, you can practically kill yourself with one decent twelve. (Not like the crap that they sell in Best Buy)
I have a custom made box for the rear with one twelve mounted in the center. I'll take a pic later today.
This is what I did quite awhile back. At the time I was thinking of putting some thumpers in but decided against it. Sounded pretty good as it was.
BTW T-tops still fit in.
http://forums.corvetteforum.com/show...um_id=3&arch=1
the maniac, (oh excuse me,audiophile) had two 10" woofers carved into the rear hatches. he burried the spare tire jack and opened the three compartments into one. he did such a neat job that i kept it. with sidepipes and spiral baffles its kind of silly but it sounds great with the motor off.
