Sponsored by: Innova
opinions needed on radar detector
Old Jan 1, 2006 | 02:09 PM
DBL001's Avatar
DBL001
Default opinions needed on radar detector
what's a good one to buy? I'm looking at all specs, IE: easiest to use, wire, sensitivity, accuracy, etc....thanks
Old Jan 1, 2006 | 02:26 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Can 'o worms.... the Detector Wars will begin... again!
Old Jan 1, 2006 | 02:29 PM
Honez's Avatar
Honez
I am no expert but about 3 months ago I got a ticket by a cop using instant on laser. After he wrote me the ticket we talked about the new instant on radar and laser detectors and bottom line is they do work the only problem is by the time they warn you it's over and they have you. While you will no doubt hear stories about how they saved many from tickets I'm not sure that they still have as much value as they use too. Someone prove me wrong please, if I thought for a moment that they truly did give you enough warrning to adjust your speed I would be the first to buy one. I live in Mission Viejo which year after year is rated as the safest city in America, that's becuase there's a cop every 100 feet or so and they all seem to have radar/laser guns pointed at you. My city is so over patroled it's not funny.
Old Jan 1, 2006 | 02:31 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Most will suggest the Valentine V1 as the most accurate/sensitive. People that own them swear by the arrows that indicate the direction of the radar.
Passport 8500 is probably the next most popular. It's smaller and cleaner in design, but lacks the arrows. Cheaper also. Pretty close to V1 in performance depending on what test you read.
If you need portablilty, the Solo II, hands down. Not as sensitive as either of the above, but very convenient to switch between cars (I drive rental cars nearly every week).
I have the Solo II and the range/sensitivity is acceptable for my use, although if I were a hard core speeder, I'd probably use the V1 even though it is a big and unattractive unit IMO.
edit to add instant on comment:
Instant on radar is easy to pick up if you have traffic ahead and the LEO zaps any of them. If you get 'cherrypicked' you are toast.
Old Jan 1, 2006 | 02:33 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
only, I choose the passport 8500.
Old Jan 1, 2006 | 02:40 PM
GR802C5's Avatar
GR802C5
What he said.
Old Jan 1, 2006 | 02:42 PM
skidmarc's Avatar
skidmarc
Unless you go with cordless, the install is going to be the same (easy to hard-wire to accessory plug in passenger footwell fuse box...I think the orange is the accessory line you want to tap into but double check that). I keep the V1 above the rear view behind the tint bar on windshield. Cannot be seen from outside the car and works great. Plus your eyes are trained to look that way periodically for the rear view anyhow. I ran the wires inside windshild pillar and trim and totally hidden.
The V1 arrows are great since you will know when you have passed the radar threat (arrows will go from in front to side and then finally to rear). Also helps in various other situtations (such as radar approaching from behind, multiple threats, etc). My .02, happy new year.
Old Jan 1, 2006 | 02:54 PM
gordonb50's Avatar
gordonb50
Although many police departments are moving towards the instant on equipment, it'll take time (and money). As they make the switch, it takes them to that new level of technology and a step ahead of the detectors. I just drove from Texas to Arizona Thursday/Friday and I'd say about 30 or 40% of the radar hits I got were the instant on ones. And with the holiday week, there were plenty of hits.
Don't know much about the radar "blockers" but I've heard folks swear by them. Prices are coming down as more people are buying them, but still high. You might do some research on them. Maybe something to help level the playing field again?
Good luck .......
Old Jan 1, 2006 | 03:05 PM
PYRO1's Avatar
PYRO1
V-1, I thought the arrows was a bunch of talk till I got mine, I love the arrows! Get one.... If you don't like it.... send it back.
Old Jan 1, 2006 | 04:36 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Got to use mine this weekend going to Dallas and back to San Antonio. This instant on got me if Leo wanted as I was going 8 over the posted speed and he got me popping over a hill so I never changed speed and he must have wanted the 10+ over crowd.
Old Jan 1, 2006 | 04:41 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I just bought a Escort 8500 X50 from another from member (Thanks Mickey ) and really like it. Sleeker in design than the V1 and ivery user friendly. Its kept me out of trouble a couple of times.
Old Jan 1, 2006 | 05:23 PM
jman1's Avatar
jman1
get a v1 or an escort..... and be ready to get flamed on either choice
Old Jan 1, 2006 | 05:38 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Everytime this topic came up, the V1 came out on top...well, at least in my eyes.
Old Jan 1, 2006 | 05:44 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Originally Posted by Honez
... we talked about the new instant on radar and laser detectors and bottom line is they do work the only problem is by the time they warn you it's over and they have you.
Yes, they do work.
And if it is instant-on or laser and you are cherrypicked... well... it gives you time to go ahead and pull over and get your license and registration ready well in advance of the officer stopping behind you and walking up to your car. Might save a couple minutes off the "stop" time.
For those in front license plate states that don't have their front plate mounted, you might even have enough time to get it bolted to the car.
Oh, I prefer the 8500 x50.
IdleCap's Avatar
IdleCap
Exactly
Old Jan 1, 2006 | 06:15 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Hang on a minute, let me put my flame retarding suit on. I just bought and installed the Belltronics Vector 995, does what everyone else's does, but only 295.00. Different tones forX,K,Ka, laser and Ku bands front and rear detection, fully programmable for alerts, tech display that will disply the numeric frequency for the radar its detecting...hold on I sound like an informercial. Beltronics.com
Old Jan 1, 2006 | 06:27 PM
Tigershark3's Avatar
Tigershark3
Passport 8500 X50 - no need to wire into fusebox - get a wire from invisacord.com and wire into the mirror. They are a supporting forum vendor.
To opinions needed on radar detector
Old Jan 1, 2006 | 06:36 PM
SLPRC5's Avatar
SLPRC5
Originally Posted by Rogue Wave
Yes, they do work.
..specialy if the LEO spots the detector in the windshield. I have the PP8500X50 and got nailed by instant on 13 MPH over the speed limit = $173.00 In the great state of Texas.
Old Jan 1, 2006 | 09:13 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
I live in Cincinnati. The home of Escort and Valentine.
Jim Jaeger and Mike Valentine were classmates (Univ Cincinnati) and were Electrical Engineers.
They cofounded Escort many years ago. Then they went their separate ways.
I had a friend (now deceased) who worked for Escort. He was in Research and Development (R&D). He admitted to me that Valentine was more sensitive and that he was working to catch up.
I currently have a V1 and it works great. The arrows do provide "value added". I have had several Escorts too.
I believe you get what you pay for.
Old Jan 1, 2006 | 09:18 PM
mwbmd11's Avatar
mwbmd11
Belltroinics RX-65. I have the 8500 as well but for the price I don't think the RX-65 can be beat. $210 on ebay by the way Belltronics and Passport are the same company now.
