need help with invisi cord
I am trying to install my invisicord ( plug in to dimmer mirror on c 6)and It will not insert into the female pink hole( 1st time I have ever had that problem) other then viagra any ideas I do not want ot rape it
I sent a reply to you (I believe it was you) from the invisicord email account. I want to make sure the positive connector is flattened. If it is not, it will not slide in next to the factory connector. I might have missed a quality control step and if so, I am very willing to send you a replacement see if it solves it. The other item to look at and/or try is to try to put the connector into a different side of that port, since the factory connector might have no gap on one side but might on the other.
