Sponsored by: Innova
Finished the C4 stereo install
Old Jan 6, 2006 | 10:11 AM
mitchcole's Avatar
mitchcole
Default Finished the C4 stereo install
I've hated the Bose stereo since I bought this car. It didn't help that I didn't even have the CD player.
The goals were to have a head unit that fits in the big hole and sounds good. I picked up the Pioneer FH-P4200MP.
I used the advise tips in the stickies and fashioned the front speaker housings to hold a pair of pioneer 4" two-way speakers. In the back, I managed to get a set of the base stereo system speaker mounts which hold a 6 x 9 speaker. These holes have the pioneer 6x9 3 ways. All the speakers were picked up at Walmart for cheap.
The plan is to use the head unit as a high pass amp for all four speakers and run a powered sub for the low frequencies. The pioneer is nice that way since it has internal electronic crossovers.
Last but not least - the iPod connection. Using the AUX adapter for the head unit - it gets you to a couple RCAs.
I then use a 1/8" female jack from radioshack,
cut up a pair of RCA cables and solder the ground and signal wire to the jack. Drill a small hole in the dash and glue the jack into the dash from the back side, plug the RCAs into the AUX adapter and then have a 1/8" to 1/8" male to male cable connecting the headphone connector on the iPod into the jack that is now on the dash.
After messing with the crossover frequencies and equalizer, it sounds great.
The biggest challenge was the wiring from the stock bose to the Pioneer head unit. It turns out that the tuner has all the connections and it's located underneath the glove box on the passenger side. A real pain to get to. And because of the distance, the harness wasn't long enough so I had to extend the whole thing. (PITA). Overall I'm very pleased. It looks good, not obvious, the sub doesn't take up much room relative to the volume, and it was relativly cheap. I think I'm into this for about $650-$700. Between Walmart and Ikesound, the component costs were bearable.
I need to take a few pictures of the finished installation.
Old Jan 6, 2006 | 03:45 PM
SteelBlue90's Avatar
SteelBlue90
Look forward to the pics. Been thinking about doing this myself.
Old Jan 6, 2006 | 08:06 PM
1991 C4's Avatar
1991 C4
Cruise-In VII Veteran
St. Jude Donor '06
Here's what I put in my 91. And what was so cool, the radio fit perfect in the opening with no mods to the plate.
Old Jan 6, 2006 | 11:47 PM
mitchcole's Avatar
mitchcole
the images are pending approval
Old Jan 7, 2006 | 04:22 AM
comp's Avatar
comp
i'd like to see finished
Old Jan 7, 2006 | 08:09 AM
JerrysVette's Avatar
JerrysVette
I like the double din stereos that fill the gap. I currently have a Pioneer DEH cd player and want to upgrade to dvd/cd. I installed a JBL 755.6 6 Channel amp powering 4 5 1/4's up front, 2 6X9's in the back and 2 12" JBL subs. BNeedless to say I have no storage in the back anymore, but the speaker box is less than 8 inches high so I can still pull the rear cover out to cover the equipment. It sounds great. I will try to post some pics.
Old Jan 7, 2006 | 11:28 PM
mitchcole's Avatar
mitchcole
Here's the install pics:
One of my favorite things is the lack of a ton of different amps and other hardware lying around..... I like a clean look.
To Finished the C4 stereo install
