Sponsored by: Innova
Ipod, Stock Amp Radio Problem
Old Jan 18, 2006 | 06:22 PM
Drav1212's Avatar
Drav1212
Default Ipod, Stock Amp Radio Problem
I have an 03, Special Edition Convertable.
I would like to instal an IPOD to the system. I just found out that I do not have a stock wire running to the trunk for a CD changer. However, I found out that I have, what appears to be, a stock AMP in the trunk, sitting in the left side hole.
I do not have the two connectrs at the front right passenger seat (See photo). It looks like the amp is wired through those connenections.
So, I am now assuming, that the AUX space in the back is now taken up with the AMP. So, now I am in big trouble.
If I take the HU out and replace, What will happen to the AMP. I would have to replace the AMP too, b/c I am sure the amp is feeding the speakers???
ANY suggestions????
THanks
Old Jan 18, 2006 | 06:25 PM
Drav1212's Avatar
Drav1212
I have pictures of it but I dont knwo how to post a picture here. Any help on how to post pictures??
Old Jan 18, 2006 | 08:23 PM
scott_fx's Avatar
scott_fx
go to www.onfinite.com and upload them there then put the link to the uploaded picture surrounded by the image tags. i.e.: [IMG]http link [/IMG]
Old Jan 18, 2006 | 08:36 PM
Drav1212's Avatar
Drav1212
Not ure if this is going to work
Old Jan 18, 2006 | 08:39 PM
Drav1212's Avatar
Drav1212
There is NO connecters for the CD changer here. it seems to be the wiring to the AMP directly.
Old Jan 18, 2006 | 10:10 PM
scott_fx's Avatar
scott_fx
didnt know there was a difference between the 03's. you aren't out of luck. as long as you bose h/u has the cd/aux button all you have to do is get the correct cable that plugs into the back of hte head unit. i believe the two you need are the cor-har and the gm-aux10 or something like that (my mnid is a bit foggy right now). i'm busy at work right, but i'll try to get you the specifics later...or whoever has done this will probably chime in
Old Jan 18, 2006 | 10:16 PM
Drav1212's Avatar
Drav1212
Found Wire
Old Jan 18, 2006 | 10:18 PM
Drav1212's Avatar
Drav1212
OK, NOW I found a Male end and I have a female end, with leads going back to the trunk. Do I have everything I need to hook up the STUFF for an IPOD connction?
Old Jan 20, 2006 | 12:33 AM
markcz's Avatar
markcz
The 3-pin plug you have pictured in posts #7 & 8 is one of the two you need. There should be another 4-pin plug in there somewhere. What's that connector in the back of your picture with the blue piece on it?
Once you find the 4-pin plug, those two plugs are where the COR-HAR cable plugs into. Then connect the GM10-Aux to the COR-HAR and you'll have RCA inputs to your stock HU.
You can run the cable under the trim/carpet to the back if you want to, but there is plenty of room above the passengers feet if you'd prefer to just tuck it up under the front dash, your choice.
I'm guessing that you have the selective ride control system in your car because the "amp" you found is actually the control system for it.
From GMpartsDirect.com:
GM PART # 10302714
CATEGORY: Electronic Control Suspension Hardware
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $809.18
OUR PRICE: $461.23
DESCRIPTION: MODULE
If you have any more questions just ask away
To Ipod, Stock Amp Radio Problem
