Sponsored by: Innova
ac problem
Old Jan 20, 2006 | 11:54 AM
GO2MCD's Avatar
GO2MCD
2nd Gear
Default ac problem
97 vette 3k miles-cold on the right -warm on the left--tried all adjustments/relay/disconnect battery --doesnt get cool on drivers side,will heat up but wont cool--right side works fine.
Old Jan 20, 2006 | 12:46 PM
scott_fx's Avatar
scott_fx
you may have better luck with this question in the c5 general section. this forum deal more with audio related electronics. but i hope someone proves me wrong
Old Jan 20, 2006 | 09:49 PM
markcz's Avatar
markcz
If you have the automatic A/C controls your damper motors may just need to be 'recalibrated', with the car running and A/C on, try pulling/reinstalling fuses #18 & 27 in the passenger floorboard, the motors should reset when power is reapplied if that's the problem.
Good luck
To ac problem
